I'm working on a project where we are mainly using the RealView compiler together with Keil uVision. We are now considering adding a third party driver that is created with the GNU toolchain in mind.
Is it possible to link my RealView project with object-files created by gcc?
Is there any table available on C interoperability between compilers (for the ARM architecture)?
Best Regards Ã…ke Forslund
"Is there any table available on C interoperability between compilers (for the ARM architecture)?"
Does the ARM Binary Interface (ABI) spec help?
See: http://www.keil.com/forum/docs/thread10643.asp
Thanks,
it did help. I'm still a bit fuzzy on the details but as far as I can understand matters it should work.
/Ã…ke
The qeustion is: has been the library created with a GNU compiler that supports EABI? If so, is the EABI standard used in the library.
Did you test to link in the library?
As I wrote above we are at the moment evaluating the software and haven't as of yet received anything more than a detailed API description so I have no possibility to test linking it yet. But I'll see if I can make sure that the library is built using the EABI standard.
Many thanks /Ã…ke
