I am using the Cypress EZUSB system with the Keil compiler(compiler 6.10, linker 4.03). When trying to debug the ISOSTRM sample app, I got the infamous 'MONITOR ERROR 22:NO CODE MEMORY AT ADDRESS 0045H' message.
The app note at http://www.keil.com/support/docs/863.htm told me to hack the USBJmpTb.a51 file and rebuild. I did so, then discovered I also needed to rebuild the monitor to apply the changes. I rebuilt in %CYUSB%\Target\fw\FX2 and got the linker error L251. The man page @ http://www.keil.com/support/docs/1827.htm tells me to use the full version of the Keil product to rebuild. I don't have the full version.
Is there another way around this BUG??
Eric
"Can anybody try this circuit?"
I tried it and it sucks eggs, like everything else you do.
