How does memory get allocated for the structure on Keil C51 8.x? Is it when I populated the contents of the structure right after declaring the structure does the memory get allocated. I am using a global var. to declare the structure.
Sam
That's got nothing to do with Keil C51 in particular, nor with it being a struct rather than some other type of variable.
All variables of static storage duration are allocated at build time, by the compiler and linker.
Are you talking about the memory layout of the structure or are you talking about placing of structure.
Declaring variables (be they structures or built-in data types) are no different from any other C/C++ compiler. The handling of global, static and auto variables follows from the requirements of the C standard.
Declaring a struct just informs about what a struct is - no memory allocated.
It isn't until you create a variable (whatever data type) that the compiler have to either allocate room on the stack or inform the linker about the symbol name and required amount of memory. How the startup code assigns initialized values to global variables is a completely different matter, and should normally be seen as a "magic" action somehow performed by the startup code.
