Hello all.
I have downloaded the LPC213x sample codes for Keil, at NXP website: www.standardics.nxp.com/.../
I have tryed to compile the GPIO example, and I am getting the following error message, when trying to compile timer.c code:
Build target 'MCB2140 Board' assembling Startup.s... compiling irq.c... compiling fiotest.c... compiling fio.c... compiling timer.c... *** MSR CPSR_c, #(0x12|0x80) ..\COMMON\SRC\TIMER.C(35): error C197: inline-asm: invalid expression token *** MSR CPSR_c, #(0x12|0x80) ..\COMMON\SRC\TIMER.C(35): error C197: inline-asm: missing ')' Target not created
The error is about this part of the code, more especificly about the IDISABLE command:
void Timer0Handler (void) __irq { T0IR = 1; /* clear interrupt flag */ IENABLE; /* handles nested interrupt */ timer_counter++; DISABLE; VICVectAddr = 0; /* Acknowledge Interrupt */ }
This IDISABLE command is defined on the IRQ.H file, and somehow it is causing this error:
#if NESTED_INTERRUPT #define IDISABLE __asm { LDMFD SP!, {LR} } \ __asm { MSR CPSR_c, #(IRQ32Mode|I_Bit) } \ __asm { LDMFD SP!, {LR} } \ __asm { MSR SPSR_cxsf, LR } #else #define IDISABLE ; /* do nothing */ #endif
If anybody knows how to solve this problem, please help me. Thank you.
