Building hex file with external function
I want to build a system where all the standard functions are already in FLASH (something like a BIOS), this is no problem to generate this.
But, how can I build and link/locate an other application without having the functions which are already in the flash.
So how can I tell the linker/locator that the library functions are available and are at there addreses?
Regards Mark,
  • I think that you will not be able to build your application with unresolved objects. I have not tried (just compiled) but I think you just can define your functions using the addresses as follows:
    #define MY_FUNC_ADDR 0x1000000
    typedef void (*func_t) (void);
    func_t my_func = (func_t) MY_FUNC_ADDR;
    my_func();
    Thomas
  • As Thomas suggested, you should be able to locate the BIOS functions at certain addresses and call them using those addresses. It can be done with macros:
    #define bios_func ((void (*)(void))0x123456)
    bios_func();
    If the BIOS uses any static variables, you must make sure they don't clash with the main program's variables.
