Does Keil software simulate the AD converter? I had been trying to use an AD interrupt (finish of the convertion), but it didn't occur (after starting the AD of course).
Depends on if the ADC is supported for the specific chip.
If supported, then the ADC conversion interrupt will work in the simulator.
I use lpc2144, which support this interrupt. An interrupt doesn't occur. Why? That's my code:
int meas;
void AD_Isr(void) __irq { meas = AD0DR1 ; VICVectAddr = 0; // reset VIC }
int main (void) {
VICVectAddr2 = (unsigned long)AD_Isr; VICVectCntl2 = 0x00000032;// Channel1 AD as interrupt VICIntEnable |= 0x00040000;//Enable the AD interrupt AD0INTEN = 0x00000002; // Enable channel_1 interrupt AD0CR = 0x00000A02; // select channel_1 (P0.28) AD0CR |= 0x1000000; // start AD conversion !!!
while(1){} }
I wasn't talking about support for ADC in the chip, but if the ADC was supported in the Keil simulation.
This page doesn't mention that the ADC is simulated for the 2144: http://www.keil.com/dd/chip/3933.htm
By the way: Do did read the instructions about how to post source code, did you?
Thank You.
P.S. No, I don't. I won't do this mistake again.
