Hello.
I have a problem with loading image into uC flash memory. Every time when I try to do so, I get message "JTAG Communication Failure" and "Cannot Load Flash Programming Algorithm". I'm sure that I've configured the "Target" section properly for my device. I'm using standard ULINK which was included to this evaluation board. I will be extremly grateful for any help in solving this problem.
Check if ULINK can talk in general to the device. Open the dialog Project - Options - Debug - ULINK Settings and reduce the JTAG clock.
See: www.keil.com/.../ulink2_su_dev_chain.htm
The STR912 device should contain 3 devices.
It seems that is was truly a matter of JTAG speed. Thank You for solving my problem. ULINK works fine now.
