The crystal is a 12 Mhz //#include "F100GlobalDataTypeDefs.h" //#include "F100GlobalDef.h" //#include "F100GlobalVars.h" //#include "F100Functions.h" //#include "F100HW.h"
void msecWait(uint milliSeconds) { /* Since the counter counts up it is necessarey to subtract the nuber of counts/millsecnd from the maximum count for the sixteen bit unsigned intiger (65535 - 922 = 64613 = 0xFC65) seperated into bytes (uchar) hiByte = 0xFC and lowByte = 0x65 */ // uchar highByte = 0xfc, lowByte = 0x65; //922 counts/(milisecond up count) // count is from 64613 (0xfc65)
// bit bitET0, bitTR0;
/************ Based on 12 MHz crystal**** Input in miliseconds ***************
bitTR0 = TR0; // Save TR0 // TR0 = 0; // Stop T0 // bitET0 = ET0; // Save ET0 // ET0 = 0; // Disable T0 // while (milliSeconds > NOMILLISECONDS) { TH0 = highByte; TL0 = lowByte; TR0 = 1; //start timer 0 // while (!TF0) {;} TR0 = 0 ; // stop timer 0 // TF0 = 0 ; milliSeconds--; } ET0 = bitET0; // Restore ET0 // TR0 = bitTR0; // Restore TR0 // */ }
It's the 3rd of the 4 bullet points immediately above the 'Message' box where you type your post!
Use the 'Preview' button to confirm that it's legible.
And describe how you've determined that it's "too fast"
Where's the question?
Please use the pre and /pre tags when posting source code.
...and it seems to be all comment (?).
-- Joost
Did you took care about the mode in which the timer0 is running. Its possible that the timer is running as 8 bit timer and not 16 bit as intended.
Suvidh
Question is why does it?
The set up is:
//--------- Serial Communication Set-up ----------- SCON = 0x70; // Set serial communication in mode 01 // (8-bit) and reciever enabled (RI = 1). PCON = 0x00; // Set SMOD0 = 0. T2CON &= 0xF0; // Set timer 2 as baud rate generator. RCAP2H = 0xFF; // Set 9600 baud high. RCAP2L = 0xD9; // Set 9600 baud high. SADEN = 0xFF; // Enable slave address // for automatic address recognition. SADDR = F100ADDRESS; // Address of data byte (0xF3). RCLK = 1; // Receiving baud rate clock. TCLK = 1; // Transmission baud rate clock. SM2 = 1; // Enable automatic address recognition. IE = 0x1E; // Enable timer 1, 0, External 1, and serial interrupts. EA = 1; // Enable global interrupt flag. TR1 = 1; // Start timer 1. TR2 = 1; // Start timer 2. ET1 = 1; // Enable Timer 1 interrupt. EX1 = 1; // Enable External interrupt 1. IP = 0x10;// Set Serial Interrupt as highest priority.
Checking on th 8-16 bit
SCON = 0x70; // Set serial communication in mode 01 // (8-bit) and reciever enabled (RI = 1). PCON = 0x00; // Set SMOD0 = 0. T2CON &= 0xF0; // Set timer 2 as baud rate generator. RCAP2H = 0xFF; // Set 9600 baud high. RCAP2L = 0xD9; // Set 9600 baud high. SADEN = 0xFF; // Enable slave address // for automatic address recognition. SADDR = F100ADDRESS; // Address of data byte (0xF3). RCLK = 1; // Receiving baud rate clock. TCLK = 1; // Transmission baud rate clock. SM2 = 1; // Enable automatic address recognition. IE = 0x1E; // Enable timer 1, 0, External 1, and serial interrupts. EA = 1; // Enable global interrupt flag. TR1 = 1; // Start timer 1. TR2 = 1; // Start timer 2. ET1 = 1; // Enable Timer 1 interrupt. EX1 = 1; // Enable External interrupt 1. IP = 0x10; // Set Serial Interrupt as highest priority.
Isn't that better?
