Hi!
Ive got an old program which i wrote on 3.02 version(compiled under CARM). Today i downloaded the latest version of MDK-ARM(3.05) because code needs some modification i cant get it to run.Everytime i get this message --- Error: can't execute 'C:\Keil\ARM\BIN\AA'
I checked Use Keil Compiler box in options and nothing. I also try to compile it under Real View Compiler so made new project and did some modification in code and this time im getting SWI when jump to main is made in startup file.
Would be grateful for any help.
Regards!
Hello john, the Keil people after merging with ARM, they are discontinuing support for CARM. So inorder to remove the problem, try to install the CARM patch.The address is http://www.keil.com/support/docs/3257.htm
