Hello folks. I am attempting to test serial comms on the MCB2140. While I have tested transmit with strings and single characters, I have yet to get coherent data from a device into the LPC2148.
Here is the current, simple program I am using, modified from examples found on Keil's website.
#define CR 0x0D #include <LPC21xx.H> void init_serial (void); int putchar (int ch); int getchar (void); unsigned char test; int main(void) { init_serial(); while(1) { putchar('?'); //checks for working output putchar(getchar()); //Echo terminal } } void init_serial (void) /* Initialize Serial Interface */ { PINSEL0 = 0x00000005; /* Enable RxD0 and TxD0 */ //PINSEL0 = 0x00050000; /* Enable RxD1 and TxD1 */ U0LCR = 0x00000083; /* 8 bits, no Parity, 1 Stop bit */ U0DLL = 97; /* 9600 Baud Rate @ 15MHz VPB Clock */ U0LCR = 0x00000003; /* DLAB = 0 */ } int putchar (int ch) /* Write character to Serial Port */ { if (ch == '\n') { while (!(U0LSR & 0x20)); U1THR = CR; /* output CR */ } while (!(U0LSR & 0x20)); return (U0THR = ch); } int getchar (void) /* Read character from Serial Port */ { while (!(U0LSR & 0x01)); return (U0RBR); }
Upon running, I see a question mark, like I expect, but no further data. I have a straight cable plugged into UART0, and hyperterminal configured for 9600 8N1. I also tested this on some old black box serial device, but had no better results. I expect it to wait for input (it does) and echo back from the hardware whatever key I send. Anyone able to help offer insight into the situation as to why I cannot receive?
My apoligies.
My code was working exactly as it should. My problem lies in the cable I was using. Problem solved.
