Hi, my eval board is Phytec KC-161 (with 64k ext RAM, and 256k ext FLASH). Why the target doesn't initialize arrays in free running? Thank you.
Could you provide the following information to see what might be your problem?
1) The size of your array? 2) The address of the array from the map file? 3) The declaration of the array in the C file?
...and the startup file (startup.a66) that initializes the vars.
Thank you for for paying atention, Chris Wunderlich . The information you requested is: My simple code is:
#include <reg161.h> void main (void) { unsigned char array[6]={1,2,3,4,5,6}; while (1) {} }
(1),(3) the size and the declaration - look above; (2) If it'll help you to discover what may be the problem, I pasted the important parts(I think so) from two files(Ithe 'array' word is red as to find it quickly): -> "Phytec KC161.lst"
C166 COMPILER V6.06, PHYTEC_KC161 04/25/2007 09:50:00 PAGE 2 NAME CLASS SPACE TYPE OFFSET SIZE ---------------------------------------------------------------------------- BUSCON1. . . . . . . . . . . . . . . . sfr uint FF14H 2 .. .. main . . . . . . . . . . . . . . . . . public FCODE funct ----- array. . . . . . . . . . . . . . . . auto array 0H 6 ?tpl?0001. . . . . . . . . . . . . . . static NCONST array 0H 6 MODULE INFORMATION: INITIALIZED UNINITIALIZED CODE SIZE = 20 -------- NEAR-CONST SIZE = 6 -------- ......
-> "project.m66" :
....... MEMORY MAP OF MODULE: .\Object\project (PHYTEC_KC161) START STOP LENGTH TYPE RTYP ALIGN TGR GRP COMB CLASS SECTION NAME ===================================================================================== 000000H 000003H 000004H --- --- --- --- --- --- * INTVECTOR TABLE * 000004H 000005H 000002H XDATA REL WORD --- --- GLOB --- ?C_INITSEC 000008H 00000BH 000004H --- --- --- --- --- --- * RESERVED MEMORY * 00000CH 00001FH 000014H CODE REL WORD --- --- PUBL FCODE ?PR?PHYTEC_KC161 0000ACH 0000AFH 000004H --- --- --- --- --- --- * RESERVED MEMORY * 0000B0H 0001CDH 00011EH CODE REL WORD --- --- PRIV ICODE ?C_STARTUP_CODE 004000H 004005H 000006H DATA REL WORD --- 1 PUBL NCONST ?NC?PHYTEC_KC161 008000H 0080FFH 000100H DATA REL WORD --- 2 PUBL NDATA ?C_USERSTACK 00D900H 00DFFFH 000700H --- --- --- --- --- --- * RESERVED MEMORY * 00FA00H 00FBFFH 000200H --- --- --- --- --- --- * SYSTEM STACK * 00FC00H 00FC1FH 000020H DATA --- BYTE --- --- --- *REG* ?C_MAINREGISTERS .......... SYMBOL TABLE OF MODULE: .\Object\project (PHYTEC_KC161) VALUE TYPE REP LENGTH TGR SYMBOL NAME ========================================================= 00000CH GLOBAL LABEL --- --- main 004000H SYMBOL VAR --- --- ?tpl?0001 00000CH BLOCK LVL=0 0014H --- main 00000EH BLOCK LVL=1 0012H --- 000000H SYMBOL AUTO --- --- array --- BLOCKEND LVL=1 --- --- ........
Hi, Joost Leeuwesteijn. ...and the startup file (startup.a66) that initializes the vars. But what should I modify in statup.a66 file that could initialize vars?
See: http://www.keil.com/support/docs/2330.htm http://www.keil.com/support/man/docs/c166/c166_ap_start167_a66.htm INIT_VARS and CLR_MEMORY http://www.keil.com/forum/docs/thread8190.asp
But your array is not a global so this should not apply... I expect the values to be in the "?tpl?0001" section but I'm not sure.
Maybe the compiler optimized it away, if this really is all your code. You could check the assembly file.
Thanks for those links, I'll see what can I do. Maybe the compiler optimized it away, if this really is all your code. You could check the assembly file. No. That code was just where I discovered the problem. I also tryed the follow code using Hyper Terminal. In debug mode the target is running well, but in free running not:
#include <reg161.h> #include <stdio.h> void setup_serial(); void main (void) { unsigned char cnt,array[6]={1,1,1,1,1,1}; setup_serial(); for(cnt=0; cnt<6; cnt++){ if(array[cnt] != 1) putchar('!'); else putchar('1'); //in hyper terminal is displaying six of '!', WHY? //it must be six of '1'! } while (1) { } } void setup_serial(){ P3 |= 0x0400; /* SET PORT 3.10 OUTPUT LATCH (TXD) */ DP3 |= 0x0400; /* SET PORT 3.10 DIRECTION CONTROL (TXD OUTPUT) */ DP3 &= 0xF7FF; /* RESET PORT 3.11 DIRECTION CONTROL (RXD INPUT) */ S0TIC = 0x80; /* SET TRANSMIT INTERRUPT FLAG */ S0RIC = 0x00; /* DELETE RECEIVE INTERRUPT FLAG */ S0BG = 0x19; /* SET BAUDRATE TO 19200 BAUD AT 16MHZ */ S0CON = 0x8011; /* SET SERIAL MODE */ }
> In debug mode the target is running well, but in free > running not
What do you mean exactly? Debug mode is on a simulator? Or on the target? And free run is on the target? Could there be a problem in the memory map/linker file? Is everything located in RAM?
What does the array contain in the incorrect situation?
- What do you mean exactly? Debug mode is on a simulator? Or on the target? I mean debug mode is on the target. - And free run is on the target? Yes. Free running I mean the execution of the device after I download the .H86 file to flash of the board.
- What does the array contain in the incorrect situation? I think that the length is not defined. When I tryed to determine what the array contains i think is 0xFF...
Thank you...
might be wrong. You should better have written
if(array[cnt] != '1') putchar('!');
I though Phytec gives you a START167.A66 file with the correct settings of the memory. But it looks like you are using a standard one and as Joost implied you most likely have a problem with this setup.
I believe you have the data set to Flash this is your problem. You need the data in RAM.
I would suggest that you look for this *.a66 file from Phytec or make sure you have the correct settings for SYSCON and only use the RAM on-chip for now. Your memory settings should look something like this:
From the *.lnp file
"START167.obj", "main.obj" TO "test" IXREF CLASSES (ICODE (0x0-0xBFFF), NCODE (0x0-0xBFFF), FCONST (0x0-0xBFFF), HCONST (0x0-0xBFFF), XCONST (0x0-0xBFFF), NCONST (0x4000-0x7FFF), NDATA (0xC000-0xD7FF, 0xF600-0xFDFF), NDATA0 (0xC000-0xD7FF, 0xF600-0xFDFF), SDATA (0xC000-0xD7FF, 0xF600-0xFDFF), SDATA0 (0xC000-0xD7FF, 0xF600-0xFDFF), IDATA (0xF600-0xFDFF), IDATA0 (0xF600-0xFDFF), FDATA (0xC000-0xD7FF, 0xF600-0xFDFF), FDATA0 (0xC000-0xD7FF, 0xF600-0xFDFF), HDATA (0xC000-0xD7FF, 0xF600-0xFDFF), HDATA0 (0xC000-0xD7FF, 0xF600-0xFDFF), XDATA (0xC000-0xD7FF, 0xF600-0xFDFF), XDATA0 (0xC000-0xD7FF, 0xF600-0xFDFF)) CINITTAB (0x0-0xBFFF)
Then you will get something like this which should work.
C166 COMPILER V6.06, MAIN NAME CLASS SPACE TYPE OFFSET SIZE ---------------------------------------------------------------------------- main . . . . . . . . . . . . . . . . . public NCODE funct ----- array. . . . . . . . . . . . . . . . auto array 0H 6 ?tpl?0001. . . . . . . . . . . . . . . static NCONST array 0H 6 START STOP LENGTH TYPE RTYP ALIGN TGR GRP COMB CLASS SECTION NAME ===================================================================================== 000000H 000003H 000004H --- --- --- --- --- --- * INTVECTOR TABLE * 000004H 000005H 000002H XDATA REL WORD --- --- GLOB --- ?C_INITSEC 000006H 000125H 000120H CODE REL WORD --- --- PRIV ICODE ?C_STARTUP_CODE 000126H 000139H 000014H CODE REL WORD --- 2 PUBL NCODE ?PR?MAIN 004000H 004005H 000006H DATA REL WORD --- 3 PUBL NCONST ?NC?MAIN 00C000H 00C1FFH 000200H DATA REL WORD --- 1 PUBL NDATA ?C_USERSTACK 00FA00H 00FBFFH 000200H --- --- --- --- --- --- * SYSTEM STACK * 00FC00H 00FC1FH 000020H DATA --- BYTE --- --- --- *REG* ?C_MAINREGISTERS
If you are a student then you can post your email and I will send you a project.
-Chris
Thank you , Chris Wunderlich.
Yes , I'm a student and I have to do a project to take my degree. My profesor gave me an eval board and have problems at the begining of the project.
Well, if you can give a project with proper settings , my email is damian_dumitras@yahoo.com (or, if it is restricted: damian_dumitras @.. yahoo dot com)
Thank you very much.
might be wrong.
No , it was correct. I made just a simple initialization, and tested if it had done...
No, the array is initialized with 1, not '1', so you should also check using 1 (not the ASCII value).
-- Joost
Sorry, maybe I didn't understand. the array is initialized with 1, not '1' Yes, it is... you should also check using 1 (not the ASCII value). So , i did. But not this is the problem , the problem is that after the initialization unsigned char array[6]={1,1,1,1,1,1}; the elements of the array are not values of 1 like I expect, so it isn't initialized. And I think the problem is in the project settings or startup file, where I don't know the solution...
I modified the project, except the startup file, and no changes have made... What and how can I modify in the startup file?
