Hi all.
Does it possible to use local C-vars in "#pragma asm" block? I mean something like this:
void Foo(void) { BYTE t; #pragma asm mov r0, t; // error A45: UNDEFINED SYMBOL ...
I have no idea as to your specific situation, but when doing the right thing (making assembly a separate module - your example does not require asm) you can use this
?DT?PackBitmap?SUUPL882 SEGMENT DATA OVERLAYABLE
Nothing special. Sometimes C-compiler generates very nonoptimal code and I wish to write a piece of asm code in this case (without call of special external assemler subroutine). But I can't find a way for using local variables in '#pragma asm' block. Yes, I can use static local variable:
void foo(void) { static BYTE t; #pragma asm mov r0,t // OK ...
but in this case 't' is not in overlay analysis for local C-variables (waste of memory).
> you can use this > ?DT?PackBitmap?SUUPL882 SEGMENT DATA OVERLAYABLE
I afraid I don't understand your recipe. Can you explain in more detail?
Alex.
look up OVERLAYABLE in the manual
if your problem is the rest, I just, to get it right, copied it from an actual assembler module, thus whatever the sement names are.
Thank you for hint, I have read the documentation and have learned something about naming of segments of automatic variables. But I still can't figure out how to use it. I suspect it's impossible ...
Well, I always says that it's best to keep your assembler in assembler modules, and call them from 'C'.
Most requests seen about inline assembler rely upon risky (or even completely false) assumptions about what can be relied upon from the surrounding 'C'...
But, if you really must do it, you will need to look at the .SRC file generated by the compiler - that will tell you what symbol names are actually being used internally. (after all, that's what the Assembler is actually seeing...)
Remember, using #pragma ASM effectively just pastes your text into the generated .SRC A bit like a #include.
See: http://www.keil.com/support/man/docs/c51/c51_asm.htm
the issue is "do you want to fight your way through or just do it"..The real *** with #pargma asm is that the entire module must be debugged in assembler. OK, do it and then - have fun
"The real *** with #pargma asm is that the entire module must be debugged in assembler"
Yes, that's true.
So, given that you have to study the assembler in the .SRC file, and you have to debug it in assembler, where is the advantage in having it inline in a 'C' file?!
That's the other reason not to do inline assembler - specifically in C51
Thanks both of you for the response.
Agreed. But sometimes external assembler subroutine is too expensive (parameters, call/ret) and not appropriate for small local problem. I use inline asm for more effective bit operations and optimization of loops. Additional benefit is "all code in full view" (no additional files).
OK, done. Not so good, compiler creates internal names like 't?040' by unclear rules and changes suffix when I add another variable in {} block. It just that I name "impossible to use"...
"sometimes external assembler subroutine is too expensive (parameters, call/ret)"
In that case, particularly given all the other issues already noted with C51 inline assembler, expand the assembler part to a suitable extent where the overhead is no longer significant!
"I use inline asm for more effective bit operations"
In what way do you find the C51 implementation of bit operations ineffective?
"Additional benefit is "all code in full view" (no additional files)."
That's not exactly true: there is an additional file - it's the .SRC file. And this is the one you have to use for debug
Not C51 but limitations of bitwise operations in C (for example, there is no circular shift).
I should take my words back: it does not work. And if there is a global variable with the same name it will be silently used instead of the local variable ... :-(
Actually, in C51 there is. Go look up _crol_ and friends in the manual.
