unsigned char read_val1; unsigned char read_val2; unsigned char read_val3; void send_uart(void);
void send_uart() { #pragma asm
S1 EQU 08H S2 EQU 09H S3 EQU 0AH S4 EQU 0BH E1 EQU 0CH E2 EQU 0DH E3 EQU 0EH E4 EQU 0FH
W1 EQU 10H W2 EQU 11H W3 EQU 12H W4 EQU 13H
K1 EQU 14H K2 EQU 15H K3 EQU 16H K4 EQU 17H
CNT EQU 18H
MOV S1,#00H MOV S2,#0fH MOV S3,#42H MOV S4,#40H
MOV K1,#00H MOV K2,#00H MOV K3,#00H MOV K4,#00H mov r0, read_val1 ;h.b of n1 mov r1,read_val2 ;m.b of n1 mov r2,read_val3 ;l.b of n1 mov r7,#00h mov r6,#00h mov r5,#00h mov r4,#00h mov r3,#10h ;muliplier
mov a,r3 mov b,r2 mul ab ;product of r2r3 mov r4,a ;r3 in r4 mov r5,b ;r2 in r5 mov a,r3 mov b,r1 mul ab addc a,r5 mov r5,a mov r6,b jnc x1 mov a,r6 add a,#01 mov r6,a x1: mov a,r0 mov b,r3 mul ab add a,r6 mov r6,a mov r7,b jnc x2 mov a,r7 add a,#01 mov r7,a x2:
MOV SP,#30H
MOV E1,r7 MOV E2,r6 MOV E3,r5 MOV E4,r4
MOV CNT,#00H CALL SUB3224 JC ENDIT
DOAGAIN: INC CNT CALL SHIFTER24BITL CALL SUB3224
JNC KHALI1 CALL SHIFTER24BITR JMP LOOPBACK DEC CNT KHALI1:
MOV A,S1 JNB Acc.7,DOAGAIN
LOOPBACK: CALL SUB3224 JC BELOW MOV E1,W1 MOV E2,W2 MOV E3,W3 MOV E4,W4 ;PUT ONE SETB C MOV A,K1 RLC A MOV K1,A
MOV A,K2 RLC A MOV K2,A
MOV A,K3 RLC A MOV K3,A
MOV A,K4 RLC A MOV K4,A
CLR C ;------------- JMP OOOOO BELOW: ;PUT ZERO CLR C
MOV A,K1 ADD A,K1 MOV K1,A
OOOOO: CLR C ;------------- CALL SHIFTER24BITR DJNZ CNT,LOOPBACK RETT: JMP RETT
ENDIT: MOV K1,#00H MOV K2,#00H MOV K3,#00H MOV K4,#01H RET ;----------------- 24-bit Shifter ----------------------------- SHIFTER24BITR: ;S1:S2:S3:S4 CLR C MOV A,S1 RRC A MOV S1,A
MOV A,S2 RRC A MOV S2,A
MOV A,S3 RRC A MOV S3,A
MOV A,S4 RRC A MOV S4,A
CLR C RET
SHIFTER24BITL: MOV A,S4 ADD A,S4 ; RLC A MOV S4,A
MOV A,S3 RLC A MOV S3,A
MOV A,S2 RLC A MOV S2,A
MOV A,S1 RLC A MOV S1,A
CLR C
RET ;----------------- 32-BIT-24-BIT SUBSTARCTOR --------------------- SUB3224: ;E1:E2:E3:E4 - S1:S2:S3:S4 = W1:W2:W3:W4 CLR C MOV A,E4 SUBB A,S4 MOV W4,A
MOV A,E3 SUBB A,S3 MOV W3,A
MOV A,E2 SUBB A,S2 MOV W2,A
MOV A,E1 SUBB A,S1 MOV W1,A RET #pragma endasm return; } IS my procedure of calling inline function is correct,ifn't how to do it .also suggest me to receive values store in k1,k2,k3,k4 in c function
Don't keep re-posting exactly the same question in new threads!
Listen to what's been said already in your existing threads!
And read the instructions on how to post source code!
http://www.keil.com/forum/tips.asp
DON'T KEEP RE-POSTING EXACTLY THE SAME QUESTION IN NEW THREADS!
this has been posted in every re-post you have made.
IF ANYBODY REPLY TO THIS, THEY ARE SUPPORTING RE-POSTING IN NEW THREADS, SO DO NOT
