I'm getting the error "DAS Port is in wrong state" whenever i try to use or confgure the debug settings for the "Infineon DAS Client for XC16x"
This seems to be a problem releated to the development environment as if i use the "DAS Basic Client" i can see the device is connected and start/stop/reset the development environment.
Has anyone had this problem before as i need to find a way to fix this problem.
Thanks Steve
Please download the latest revision (it should be fixed in C166 V6.08). Demo Version available under: www.keil.com/.../c166.htm
Thanks that's working now.
I did download the latest version from the product updates page (http://www.keil.com/update/c166.asp) but that is only showing up to v6.06
Steve
