I try to download image from µVision3 to C8051F124-TB using SiLab using USB Debug Adapter driver and received the following message: "Target could not be reset. Confirm cable and power connections and retry."
I check SiLab USB Debug Adapter by downloading from SiLab IDE and it work just fine. Also I can download from µVision3 to C8051F020 using RS232 JTAG. It seems that there is problem to integrate USB Debug Adapter driver into µVision3.
Any idea what cause this problem and how to solve it will be appreciated.
As I know the RSR232 JTAG is about three years older than the USB JTAG.So maybe the driver should be updated. In my case the driver for USB JTAG also works with RS232 JTAG,but doesn't the RS232 JTAG's driver.
Sorry,I mistook something.
As I know the RSR232 JTAG is about three years older than the USB JTAG.So maybe the driver should be updated. In my case the driver for USB JTAG also works with RS232 JTAG,but doesn't the RS232 JTAG's driver work with a USB JTAG adapater.
Then WHAT IS YOUR PROBLEM?
The problem is that SiLab USB Debug Adapter does not work from Keil IDE.
That is only a problem for IDEiots.
Who on earth said that averything shall be friggin' 'convenient'. If it works, USE IT, if it does not work USE SOMETHING THAT DOES, is that too difficult a concept?
