In EZUSB-FX2 manual it says Timer 0 interrupt is based at int. vector 0x000B with priority 2. From the cypress tutorial example fn.,
void timer0_ISR (void) interrupt 1 seems to be hit everytime when timer expires. How does this work? I thought you need to write a jmp instruction at 0x000B location and jmp to a ISR we define.
Can someone explain
thanks ravi
Read what the interrupt keyword actually does:
http://www.keil.com/support/man/docs/c51/c51_le_interruptfuncs.htm
TFFReply!
meaning WHAT?
Thankful For Fast Reply ?
Thanks for Fast Reply ?
Would've been even quicker to have just gone straight to the Manual...
