I have the same problem described in a previous thread:
6733 ARM: uVision3 crashing whenever try to download to flash
Ian Mellor 01/18/06 12:12 (5)
There were no solutions posted to that thread. What was the outcome?
I have a number of programs which compile, download, and run just fine, so I think everything is configured "properly". The program I am working on now, however, compiles just fine, but I get the dreaded Windows' "uVision3 IDE has encountered a problem and needs to close. We are sorry for the inconvenience." when I try to download the program to flash.
Here is my toolchain config:
IDE-Version: µVision3 V3.33 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2006
Tool Version Numbers: Toolchain Path: C:\Keil\ARM\BIN30\ C Compiler: ARMCC.Exe V3.0.0.942 Assembler: ARMASM.Exe V3.0.0.942 Linker/Locator: ARMLINK.Exe V3.0.0.942 Librarian: ARMAR.Exe V3.0.0.942 Hex Converter: FROMELF.Exe V3.0.0.942 CPU DLL: SARM.DLL V3.02a Dialog DLL: DARMST.DLL V1.04i Target DLL: BIN\UL2ARM.DLL V1.20a Dialog DLL: TARMST.DLL V1.04i
I am using a Hytex STR7 Eval Board.
Any ideas?
Thanks, Erik
Hi Erik, Try the latest update . That solved an similar type of problem for me.
Suvidh
Sure enough. I downloaded and installed v3.04, and the flash is now programmed as expected.
Thanks! -Erik
