we recently got the RTX51 Tiny and want to use it with a Silicon Labs C8051F124. today i discovered various posts about problems using RTX51 with paged SFR devices. i've seen some suggestions about what to do, but have also found indications that those suggestions were lacking. so at this point, i'm not sure what to believe.
has anyone been able to get RTX51 Tiny to work reliably with SiLabs paged SFR devices? if so, can you provide me with a definitive set of guidelines for getting them to work together? or should we abandon trying to use RTX51 with the C8051F124, and look for a different RTOS or microcontroller?
any help is appreciated.
RTX51 Tiny will work with this SiLABS device. Just look here: http://www.keil.com/support/docs/3104.htm for the modifications required.
thanks, reinhard.
i had seen these instructions, but had also seen an indication that they might not take care of everything. i will try them and see if i find any problems.
steve
