Dear People who migrate from legacy Keil Tools to ARM RealView:
I am interested to use the Nested Interrupt in Software in a simple way shown in Examples. But in RealView I am not able to use Inline Assembly with Access to some Registers:
Macros for GCC and legacy Keil Tools:
// Macros for Interrupt Nesting #define IENABLE __asm { MRS LR, SPSR } __asm { STMFD SP!, {LR} } __asm { MSR CPSR_c, #0x1F } __asm { STMFD SP!, {LR} }
#define IDISABLE __asm { LDMFD SP!, {LR} } __asm { MSR CPSR_c, #0x92 } __asm { LDMFD SP!, {LR} } __asm { MSR SPSR_cxsf, LR }
In current RealView Tools it is not possible to access the Registers SP, LR, PSR via Inline Assembly with Assembler Macros. Instead of the Macros, I developed the following Assembler Functions for Embedded Assembler:
nested_irq_enable: STMFD SP!, {R0} MOV R0, LR MRS LR, SPSR STMFD SP!, {LR} MSR CPSR_c, #0x1F STMFD SP!, {LR} BX R0
nested_irq_disable: MOV R0, LR LDMFD SP!, {LR} MSR CPSR_c, #0x92 LDMFD SP!, {LR} MSR SPSR_cxsf, LR MOV LR, R0 LDMFD SP!, {R0} BX LR
The Runtime of these Instructions is a little bit longer as the Macros. Also, the Stack is affected by a Register Saving of R0.
I have tested a simple configuration, a Timer Interrupt is breaking an external Interrupt, it works very well.
Should I be concerned on it?
Is there anybody who has an Idea to make this better?
Greetings
Dietmar Wengler
