Hello Every1,
I am using P89V51RD2BN microcontroller for my project. To load the hex file into the Flash ROM, I am using Flash Magic.
I have written a simple code as follows :-
#include <P89V51Rx2.H> sbit led=0x90;
main() { unsigned int i;
while(1)
{ led = 0x01; for(i=0;i<50000;i++); led = 0x00; for(i=0;i<50000;i++);
Though the compiled hex code gets loaded into the chip, it does not get loaded at 0x0000; instead, the three bytes starting @ 0x0000 are 02 08 4E; which as per the "Disassebly" correspond to LJMP 084E.
And I find the hex file loaded in the locations from 0x8000 to 0x858.
I would like to know why is this happening? What do I need to do to load the hex file from 0x0000 contigously.
Thanks.
You are using the free Evaluation version, right?
Obviously, any free Evaluation version always has certain limitations, doesn't it?
You need to read the document describing those limitations...
http://www.keil.com/demo/limits.asp
Thank you Andy.
Also, as soon as you want to use interrupts in your program, starting the regular program code at 0x0000 becomes a very bad idea.
