Dear Sir,
Im a begginer for a assembly program like this in keil,
Mov R0,#10 ----> 480ns Mov R1,#20 ----> 960ns Mov a,R0 ----> 1440ns Add a,R1 ----> 1920ns Mov R2,a ----> 2400ns Mov a,R1 ----> 2800ns Subb a,R0 ----> 3360ns Mov R3,a ----> 3840ns
Im using C8051F410 controller with a clock frequency of 25 Mhz so the time is 40 ns. Now the first instruction takes 480ns while single stepping in keil in the seconds tab in the registers window but the instruction takes 2 clock cycles so it should be 2*40ns = 80ns, can somebody please tell me if something is going wrong or im missing anything.
I would assume that there's a certain overhead created by single-stepping, depending on the type of emulator you're using.
Also ... is your chip a 12, 6, 4 or 1-clocker ?
