Can anyone figure out why the below program does not increment the variable 'i'? The C-program shifts i to the left one bit per loop but the generated code (asm program) doesn't change the 'i' variable (constant 0)!
C51 COMPILER V8.02 MAIN 11/27/2006 17:21:15 PAGE 1 C51 COMPILER V8.02, COMPILATION OF MODULE MAIN OBJECT MODULE PLACED IN main.OBJ COMPILER INVOKED BY: C:\Keil\C51\BIN\C51.EXE main.c OPTIMIZE(0,SPEED) BROWSE DEBUG OBJECTEXTEND CODE line level source 1 2 #include <REG7C646.H> 3 4 void main() 5 { 6 1 unsigned char i; 7 1 8 1 while(1) 9 1 { 10 2 for(i = 0; i <= 0x80; i <<= 1) 11 2 { 12 3 P1 = i; 13 3 } 14 2 } 15 1 } C51 COMPILER V8.02 MAIN 11/27/2006 17:21:15 PAGE 2 ASSEMBLY LISTING OF GENERATED OBJECT CODE ; FUNCTION main (BEGIN) ; SOURCE LINE # 4 ; SOURCE LINE # 5 0000 ?C0001: ; SOURCE LINE # 8 ; SOURCE LINE # 9 ; SOURCE LINE # 10 0000 750000 R MOV i,#00H 0003 ?C0003: 0003 E500 R MOV A,i 0005 D3 SETB C 0006 9480 SUBB A,#080H 0008 50F6 JNC ?C0001 ; SOURCE LINE # 11 ; SOURCE LINE # 12 000A 850090 R MOV P1,i ; SOURCE LINE # 13 000D ?C0005: 000D E500 R MOV A,i 000F 25E0 ADD A,ACC 0011 F500 R MOV i,A 0013 80EE SJMP ?C0003 0015 ?C0004: ; SOURCE LINE # 14 0015 80E9 SJMP ?C0001 0017 ?C0002: ; SOURCE LINE # 15 0017 ?C0006: 0017 22 RET ; FUNCTION main (END) MODULE INFORMATION: STATIC OVERLAYABLE CODE SIZE = 24 ---- CONSTANT SIZE = ---- ---- XDATA SIZE = ---- ---- PDATA SIZE = ---- ---- DATA SIZE = 1 ---- IDATA SIZE = ---- ---- BIT SIZE = ---- ---- END OF MODULE INFORMATION. C51 COMPILATION COMPLETE. 0 WARNING(S), 0 ERROR(S)
Never mind! Shifting a 0 doesn't do much :)
Yes, but blame the compiler for it. :)
My Suggestion: Let's examine your code by PC-Lint. Its output could consist a warning: Variable 'i' not initialized with proper value....
cheers and *lol* Martin
i is initialized to 0 in the for statement.
Don't be serious, it was a joke... John Gulbrandsen already explained the cause.
