I need to write a C++ program with the basic instructions to create classes and objetcs for the 8051. Has anyone written a C++ program and compiled it with Keil Microvision, it supports C++ instructions like class ?
Thanks in advance.
" ... Keil Microvision, it supports C++ instructions like class ?"
No, it does not.
Keil C51 is an ANSI C compiler - it is not a C++ compiler.
http://www.keil.com/c51/
"I need to write a C++ program with the basic instructions to create classes and objetcs"
Well, that's fair enough as an exercise in C++ programming
"for the 8051"
But why would you want to do a C++ programming exercise on an 8051?!
Why not just do it on a PC?!
I have looked at the Keil Realview C/C++ compiler for ARM and have thought that the C51 also belongs to Realview and could compile C++ codes.
"But why would you want to do a C++ programming exercise on an 8051?!
Why not just do it on a PC?!"
It's just an exercise of my course.
A few years back a company called CEIBO had a C++ front end for the 8051. It would interface to the older Keil C compiliers. Don't know the present status but at the time you could download a limited eval from CEIBO. Bradford
"thought that the C51 also belongs to Realview..."
No, it doesn't, I'm afraid.
"...and could compile C++ codes"
hence it can't.
"It's just an exercise of my course."
Then there is no point in worrying about the 8051!
Just use a native PC C++ compiler - there are several free ones available (including from Borland and Microsoft).
