Is any one has solution for this PCLint Errors.
error 1762: error 1911: error 1506: error 774: error 1037: error 613: error 1037 error 931: error 1762 error 1764: error 578: error 1036 error 775: error 737: error 429: error 747: error 560: error 1705: error 550: error 685: error 568: error 1746: error 1762 error 539: error 1939 error 737: error 713: error 429: error 715: error 525: error 725: error 437: error 424: error 58: error 944: error 774: error 1036: error 944: error 681: error 64:
Or you have any Suggestion . Please write me. Thanks.
Does the code actually compile without errors and warnings?
After that, Look at each PCLint error in turn. Read the description of the error. Look at the code that produced the error. Fix the problem(s) with the code!
There is a full list of PCLint messages here: www.gimpel-online.com/MsgRef.html
For PCLint support, see www.gimpel.com/.../support.htm
A quick glance at a couple of the error numbers you mention look like C++ Errors.
Remember - Keil C251 is not a C++ Compiler!
http://www.keil.com/c251/
