V3.33 and V3.34 have the same problem. please keil test! Cursor can't move to right location in c and C++ source file.
Please check if this helps: http://www.keil.com/support/docs/3244.htm
Reinhard,Thanks for your reply. Please check if this helps. i have add this line under [UV2]. [UV2] ANSI=1 but the Display of chinese still have some problem.
Can you please send a picture that illustrates the problem to support.intl@keil.com.
