Large memory model compilation of Code.
Hi All
To define project compilation model as large,
will the folowing change to statement in "xxx.m51" file work ?
"MEMORY MODEL: SMALL" to "MEMORY MODEL: LARGE"
since i am using si-labs IDE and compiler of keil(there is no direct option for this setting).
Also using oh51 (from keil) to convert "xxx.m51"(generated by using si-labs IDE and keil compiler) to hex but oh51 was generating error "Unknown record type 42" when "xxx.m51" file was provided to it as input.
has any one tried to get hex file with si-labs IDE and keil-compiler ?
Naresh
