Hitex MX51 with uVision2, uVision3 ICE Emulator Setup
I have downloaded and installed the driver:
http://www.keil.com/download/docs/119.asp
I also have installed uv3 and the C51 tools
I can compile and run C51 programs in simulation mode, but I am not able to run it using Hitex MX51 ICE emulator.
Does anybody know a step by step procedure to setup uVision project with Hitex MX51?
Do I need also a version of HITOP-8051 be installed or the driver and the uVision IDE is sufficient?
Should I use older version of uVision such as uv2 or using uv3 is OK?
