Hi people, I have an interesting problem here. I need to generate a number (a 4-digit Integer) and give it as a command line argument to my exe file generated by the cross compiler. The problem is, EXE file would be executed by the chip & not by the PC, hence giving any command line argument would need a connection between the chip & one of the ports on the PC. Is there a way/mechanism by which I can give a command line argument during compile-time and not during the run-time? Is there any functionality provided by the tool on these lines? Regards, Jinen.
What toolset? "I need to generate a number (a 4-digit Integer) and give it as a command line argument to my exe file generated by the cross compiler." For a start, none of the Keil tools generates exe files. exe files are specifically for execution on the PC; Keil tools generate image files to be loaded (somehow) into target hardware and run there - not on the PC. "The problem is, EXE file would be executed by the chip & not by the PC, hence giving any command line argument would need a connection between the chip & one of the ports on the PC." An RS232 link is a very common way to interface a PC to an embedded system. All sorts of other interfaces are also possible to control the embedded system, including keypads, buttons, etc, etc "Is there a way/mechanism by which I can give a command line argument during compile-time and not during the run-time?" If you give it at compile time, it becomes a fixed part of the generated code - so it can hardly be called an "argument" What exactly do you mean? Perhaps if you described what you're actually trying to achieve we could come up with some suggestions as to how to achieve that...?
In the target system, who types a command line? Do you actually have a command line interface task? Or do you mean you want to pass an argument to main() -- argc and argv? These arguments are usually derived from a command line in an interactive OS by the C run-time system. In an embedded system, they're generally meaningless, unless that embedded system is running some sort of user shell. Does this value need to be altered dynamically? That is, every time the system is powered on, or the user hits a key, or some such, you need to supply a value? In this case, you'd need to describe your user interface hardware. You probably have a UART somewhere on your microcontroller, for example. Perhaps you use it for a human-readable CLI, or perhaps you just invent a protocol to send a few bytes across the serial port. If it is sufficient that the value be supplied at compile time, then all you really need to do is set a #define, or perhaps generate a small .c file with a suitable constant variable definition. That hardwires in the value, and no communication is necessary.
Thanks people for your inputs. Let me explain this in some more details. I need to assign a value to a variable in my cross compiler code from command line. This value wouldnt be altered at any point of time. This value, that i would be passing with a command line, would itself be a random value (w.r.t time) generated by another code ( I need to remove manual entries...as it is more like a security driven application..)... once i assign this value to a variable in my cross compiler code....i wouldnt need to alter it...or take any more inputs from command line.....the system that i am designing wouldnt remain connected to any system...hence there wont be any communication thing possible....its just during the burning of code into the chip...i need such a mechanism...so i can initialize my varaibles... And yes...this is similar to argc, argv in main......but with a constraint....that they should be picked during compile time....and not run time... Thanks again for replying to my question. This is for andy.....compiler is no connstraint for me....i got SCCAVR, CVAVR & some other tools here with me....incase there is any other tool....U think that can help me....U may let me know....
Think about passing it to the compilation process as a defined value on the command line. For example "-DRAND=nnnn", where "nnnn" is a random value generated by an external program or script. The program or script could invoke the compiler directly or could edit the 'make' or 'batch' file you build from.
Any clue on how to "make" a file from command line? Am able to invoke compiler from command line, but then am not too sure whether it is compiling the file. After compilation i got to 'make' to get a HEX file. is there a way of directly giving make as a command on command line and get a hex file?
"the system that i am designing wouldnt remain connected to any system...hence there wont be any communication thing possible" That's needn't be the case. Many products have an interface that is used only during the manufacturing process for test & configuration purposes. "its just during the burning of code into the chip...i need such a mechanism... so i can initialize my varaibles" So, it sounds like what you actually need is a unique identifier to be applied to each individual unit manufactured? Like a serial number, or the MAC address of an ethernet card? If so there are many possibilities: 1. you could re-compile the code for every single unit unit produced, changing a command-line define each time. This is unlikely to be practical. 2. post-process the hex file to add the unique ID at the time that each device is programmed. Any decent commercial batch programming facility should be able to do this. 3. have a hardware "module" that provides the unique ID, similar to the idea of the SIM in a GSM phone. Or something like the Maxim/Dallas "silicon serial number" http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3711 Or maybe something in your system already has a unique ID (eg, ethernet MAC)... 4. provide a test/configuration interface whereby the serial number can be programmed during manufacture; eg, to be stored in EEPROM (or flash, if in-application programming is possible) "i got SCCAVR, CVAVR & some other tools" These are all AVR tools - so why are you asking on the Keil site. The site is supposed to be for discussing Keil tools: http://www.keil.com/forum/
"....U think that can help me....U may let me know...." Who is "U" ? Is he any relation of "M" or "Q" ? Or have you just worn your fingers out with typing all those dots.....................? You've made it an uppercase 'U', so it's taking you 2 keystrokes anyway - would it be that hard to just hit one more key and make it a proper "you"? You could always economise on the dots if you're that desparate to conserve keystrokes................................!
For manipulating Hex files, look at: http://srecord.sourceforge.net/ I think it might be included in CodeVision?
Thanks alot Neil, You have got it right, its like giving a unique identity to each and every unit manufactured. Is there a way for exporting a variable from my cross compiler to any .txt file? Regards, Jinen.
"Is there a way for exporting a variable from my cross compiler to any .txt file?" What would be the point of that? What do you mean? You don't want anything from the compiler other than the executable code. The options I outlined before boil down to basically 3 types: A. Rebuild the software every time to create a unique image for each unit. Unlikely to be practical unless you have only a very small number of units indeed. B. Have your programming facility insert the code into the image at the time that you burn the Chips C. Have your code read the ID from its environment at runtime. You seem to be stuck on A; I think B or C are where you need to be looking.
"its like giving a unique identity to each and every unit manufactured" So how many units are we talking about - under 10? dozens? hundreds? thousands...? Is the "unique identity" fixed for the entire product's lifetime, or do units need to be able to have new identities?
Well, unique identity remains constant throughout the lifecycle of the product. What i need to manufacture is in 1000's approx 25k a month. I am not really stuck on A,B or C... I am just trying to visualize different options. Thanks again for replying.
the simplesolution would be to add a DS2411 Erik
"the simple solution would be to add a DS2411" Yes - that's the "silicon serial number" of my option 3: http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3711 However, this may or may not meet the OP's specific requirements for the type of number that he needs...? We await comments...
"What i need to manufacture is in 1000's approx 25k a month." So re-building the code for each individual unit to give a unique image for every single one (Option A) is clearly impractical!! Therefore you need to look at options like B or C...
