pressure
hi sir
i need one help
now iam doing project on 89c51 using C51 Evaluation Software
i converted 0-5 analog volatge to 0-5 digital voltage .
now i want convert digital data to pressure
my output should be like this
0v 1.1E-1 3v 4.1E-4
0.1 1.2E-1 4v 5.1E-5
1v 2.1E-2 5v 6.1E-6
2v 3.1E-3
i want 500 values in between 0 to 5 volts
how to calibrate the voltage interms of preesure
what logic i want use to convert Voltage to pressure
my C51 not taking floting oparations
please help
regards
chandra sri
  • "in my project iam using 4 seven segment display for to display the pressure."
    Do you mean a four-digit 7-segment display?
    If so, how do you plan to display, for example, "4.1E-4" on four 7-segment digits:
    4. = 1st digit
    1  = 2nd digit
    E  = 3rd digit
    -  = 4th digit
    4  = Oops! no more digits!!
    Or, as all the values contain the 'E' and '-', will they just be permanently marked on the panel?
    In which case, you only need 3 digits - not 4!
    "please tell how to..."
    No - you need to learn how to think these things out for yourself!
    The Lookup-Table technique can still be used; you could even still make it a table of strings.
    Instead of using printf, you just write the 1st character of the string to the left-most 7-segment digit, and so on...
    Using a table of strings for this is probably quite inefficient, because:
    1. each string has a null-terminator added, which you don't need;
    2. the actual table contains pointers to the strings (textbook basics) - so these pointers have to be stored in addition to the actual strings, With such small strings, this is a significant overhead!
    A more compact way would be to use a two-dimensional array...
    Textbook time, again!
    "Because printf is taking lot of memory"
    Yes, printf does take quite a lot of memory.
    But, in this case are you sure that it's printf that's the real problem - or is it just the size of the table?
  • Textbook time, again!
    Andy, do not come to the US, we have laws against cruel and unusual punishment :)
  • we have laws against cruel and unusual punishment
    Textbook time may be cruel, but it is certainly not unusual, and therefore perfectly fine. :)
  • "Textbook time ... is certainly not unusual"
    It seems to be becoming increasingly unusual amongst today's students... :-(
  • hi sir
    this is my code
    unsigned int voltage;
    unsigned char *pressure_string[] ={"3.07E-12","1.22E-10","6.56E-10");
    v=0x02;
    voltage=voltage*50;
    P1=string[voltage];
    For voltage=0x02 carresponding pressure is
    6.56E-10 from table.
    that is P1=6.56E-10;
    sir my doubt is PORT 1 well takes only 1 byte
    (8bits) then how it takes 6.56E-10;
    and how to devide the pressure 6.56E-10
    into "6",".=constant","5","6","E=constant",
    "-=constant","1","0" .
    sir here iam using seven numbers 7segment
    Led display for displaying the pressure.
    thank you sir
    Regards
    chandu
  • Hi sir
    how to divide the "string" into singal elements
    example:
    string={"3.56E-12") in to "3", "." ,"5","6","E","-","1","2".
    Thank you
    Regards
    chandu
  • Stop! Now!!
    You are struggling with absolutely basic concepts of both 'C' programming and, apparently, the hardware itself.
    You seriously need to set this project aside, go back to basics, and get a proper understanding in the 'C' Language
    Get yourself a good book, and study it:
    http://www.keil.com/books/8051books.asp
    http://www.8052.com/books.phtml
    "my doubt is PORT 1 well takes only 1 byte (8bits) ... i am using seven numbers 7segment LED display"
    Sure, all the 8051's ports are 8 bits (1 byte) wide.
    So how have you connected seven 7-Segment digits to your 8051?
    Obviously, the way you write stuff to the display will depend entirely on how it is connected to the 8051!!
