pressure
hi sir
i need one help
now iam doing project on 89c51 using C51 Evaluation Software
i converted 0-5 analog volatge to 0-5 digital voltage .
now i want convert digital data to pressure
my output should be like this
0v 1.1E-1 3v 4.1E-4
0.1 1.2E-1 4v 5.1E-5
1v 2.1E-2 5v 6.1E-6
2v 3.1E-3
i want 500 values in between 0 to 5 volts
how to calibrate the voltage interms of preesure
what logic i want use to convert Voltage to pressure
my C51 not taking floting oparations
please help
regards
chandra sri
  • "compiling forum.c...
    MAIN\FORUM.C(8): error C243: 'array[]': string out of bounds"
    Look-up the error in the Manual - it tells you exactly what is wrong!
    http://www.keil.com/support/man/docs/c51/c51_c243.htm
  • "how much memory well take for 500 values of the look up table"
    Keil C51 does not add any extra space for padding or alignment; therefore the size of an array is simply the size of one element multiplied by the number of elements in the array.
    The sizes of the data types used by C51 are listed in the Manual:
    http://www.keil.com/support/man/docs/c51/c51_ap_datastorage.htm
    You need to become familiar with the Manual - that doesn't mean you have to learn it by heart, but you need to be familiar with what's in it, and how to find stuff in it...
    You probably also need a good 'C' textbook...
  • sir
    i tried this expressions
    char pressure_string[] ={"1.1E-1","1.2E-1","1.3E-1"};
    it is showing same error
    char pressure_string[3] ={"1.1E-1","1.2E-1","1.3E-1"};
    it is also showing same error
    then which is correct.
    thank you
  • Oops - I made a mistake in the code I posted:
       "1.1E-1",   // Index 0 corresponds to  0mv
       "1.2E-1",   // Index 1 corresponds to 10mv
       "1.3E-1",   // Index 2 corresponds to 20mv
    Can you spot my mistake? Hint: the array contains strings
  • Iam sorry sir
    i can not spot your mistake
    please give solution for that one
    thank you sir
  • It's a classic 'C' programmer's mistake!
    You need to learn to spot these things if you want to do 'C' programming!
    (it's the kind of thing you'd get in a 'C' test at a job interview!)
    Another hint: what's the difference between a char and a string in 'C'?
    Don't be afraid to look in your 'C' textbook...
    (they probably won't let you do that in an interview, though!)
  • Have you given up?
    Try
    char * pressure_string[] =
  • hi sir
    thank you
    sir i tried this program
    unsigned int voltage;
    unsigned char *pressure_string[] ={"11E-1","12E-2","13E-3"};
    printf( "Voltage %u mV = Pressuse %s", voltage*10, pressure_string[voltage] );
    it is showing folling out put
    "voltage 10mv=pressure 13E- "
    it is not showing full value.
    regards nari
  • When you posted your data as
    0.00v =1.1E-1
    0.01v =1.2E-1
    0.02v =1.3E-1
    1.00 =2.1E-2
    2.00 =3.1E-3
    3.00 =4.1E-4
    4.00 =5.1E-4
    5.00 =6.1E-5
    I thought this showed that you understand what the little dots mean!
    The little dots mean, "this is incomplete; extra values go here"
    Thus, the table I posted
    is icomplete - it contains only the first 3 entries!
    You need to fill-in the other 497 entries!
    Your "program":
       unsigned char *pressure_string[] ={ "11E-1", "12E-2", "13E-3" };
    doesn't assign a value to 'voltage' before using it in the printf!
    It'd probably be better to add a newline at the end of the output:
    printf( "Voltage %u mV = Pressuse %s\r\n", voltage*10, pressure_string[voltage] );
    Please read the instructions on how to post code in the forum:
    http://www.keil.com/forum/tips.asp
    and use the 'preview' to check before pressing 'post'
  • Hi sir
    I assign a value to 'voltage'
    now iam geting correct values.
    up to 24 string elements [array elements]it showing correct.
    Above the 24 elements it is compiling but it is showing linking error
    the error is:
    "Build target 'Target 1'
    linking...
    *** ERROR L107: ADDRESS SPACE OVERFLOW
    SPACE: DATA
    SEGMENT: _DATA_GROUP_
    LENGTH: 0071H
    Program Size: data=123.1 xdata=0 code=1559
    Target not created*/"
    above the 50 elements it is not compiling and showing this error .
    the error is:
    " compiling forum.c...
    MAIN\FORUM.C(19): error C241: 'main': auto segment too large
    main\forum.c - 1 Error(s), 0 Warning(s). "
    regards
    chandu
  • *** ERROR L107: ADDRESS SPACE OVERFLOW
    SPACE: DATA
    This means that there is not enough memory available in DATA memory space to hold all the variables you have declared. Which is not surprising, as the 8052 only has 128 bytes of DATA memory.
    Since your programm will most likely not change the contents of the string array at run-time, you could simply store the array in CODE space instead. If the program does need to change the contents, and your device has enough XDATA memory, store the array there instead.
    Refer to the Cx51 manual for more information on memory types and areas:
    http://www.keil.com/support/man/docs/c51/c51_extensions.htm
  • Chandra,
    Is it just that English is not your first language, or do you really not understand the word "OVERFLOW" ?
    See: http://www.keil.com/forum/docs/thread7364.asp
    As Christoph says, the data in the lookup table is constant - it will not change at run-time - so you should put it into CODE space.
    You might find that you exceed the code space limit of the evaluation version, though...
  • MAIN\FORUM.C(19): error C241: 'main': auto segment too large
    All the error messages are described in the Manual:
    http://www.keil.com/support/man/docs/c51/c51_c241.htm
    In uVision, just click the message and press F1 - it will show you help for that message.
  • thank you sir
    thank you for your valueble answers
    Hear in my project iam using 4 seven segment display for to display the pressure.
    up to now iam displaying the pressure on the serial window.
    pleace tell how to display the data on 7 segment display with out using printf statement.
    Because printf is taking lot of memory .
    regards
    chandu
  • "in my project iam using 4 seven segment display for to display the pressure."
    Do you mean a four-digit 7-segment display?
    If so, how do you plan to display, for example, "4.1E-4" on four 7-segment digits:
    4. = 1st digit
    1  = 2nd digit
    E  = 3rd digit
    -  = 4th digit
    4  = Oops! no more digits!!
    Or, as all the values contain the 'E' and '-', will they just be permanently marked on the panel?
    In which case, you only need 3 digits - not 4!
    "please tell how to..."
    No - you need to learn how to think these things out for yourself!
    The Lookup-Table technique can still be used; you could even still make it a table of strings.
    Instead of using printf, you just write the 1st character of the string to the left-most 7-segment digit, and so on...
    Using a table of strings for this is probably quite inefficient, because:
    1. each string has a null-terminator added, which you don't need;
    2. the actual table contains pointers to the strings (textbook basics) - so these pointers have to be stored in addition to the actual strings, With such small strings, this is a significant overhead!
    A more compact way would be to use a two-dimensional array...
    Textbook time, again!
    "Because printf is taking lot of memory"
    Yes, printf does take quite a lot of memory.
    But, in this case are you sure that it's printf that's the real problem - or is it just the size of the table?
