mVision as an automated test tool
I want to use mVision as an automated test tool that should be able to validate the target system. I believe that the predefined test cases should comprise signal functions which run at the background of the target system.
I could use a little help on the following queries:
1. Could the test cases be part of the INI file declared at the Simulation options of the project?
2. Can I start running the target system as well as the execution of the above test cases from the command line?
3. Do I have the option to invoke a script (INI file) from the command line or a script parameter?
4. Is able a signal function to be retrieved from another signal function (inside the INI file)?
5. Is there any size limitation concerning the INI file?
Thanks in advance!
