uVision2 to Silab USB debug adapter
I have the full version Keil uV2
version 2.20a + board C8051F120-TB + USB debug adaptor and run Keil uVision Driver V1.81 for instal.Silab-driver in Keil
-connection do not work :(
This hardware work ok with uVision3 (evaluation version) (thanks Steve after copy the file USBHid.dll to uv3 directory).
I make copy the silabs..drivers from eval.uV3 to full uV2, connection work but I take message 'EVALUATION VERSION...':(
Does anyone know to make full KEIL uV2 compatible with USB debug adapter
(1.Where to put the SIC8051F_uv2.exe for instal Silab-drivers ?
2.What bottom to press (Modify or Repair)
3.Is this may be the problem :the name directory for My Keil is 'KEIL51'?
Yuri
(yuri@drive-engineering.com)
