there are many syntax errors and undefined identifiers.
I have developed programs in C and it compiles with no errors. and while compiling it in Keil compiler for 8051 MPU, there are many syntax errors and undefined identifiers. What could be problems and whr i have to consider?
Thank you
  • You have probably used extensions specific to some other compiler.
    Maybe you have some header files missing?
    See the Keil C51 Manual for details of ANSI features not supported - in particular, not all the standard library functions are provided.
    The standard approach is to start with the first error - fix that, then re-build and see how many of the others dissapear!
