Hello, I am having problem with EPM900. Whenever I am starting debugging using EPM900 I am getting message "EPM 900 Boot Loader not running." What I Have to do ?
Looks like the bondout device is not working anymore. Please contact your local distributor. Reinhard
I had similar problem. There was some pins with oxidation in PLCC socket of bondout device. The EPM900 was stored in bad environment. I solved this by (carefully) removing the bondout controller from socket, cleaning contacts with alcohol and returning it back. You will need special PLCC removal tool.
