Configure Keil uVision2 to Accutron Spear for ADuC Processors
I am using the 2K Eval version to develop code for the Analog Devices ADuC816.
The quick start kit comes from Acctron which includes a small board called Spear . This board plugs into the serial port on the PC and the EA/ pin on the processor to access the on-chip debug features.
I have used this feature using the Accutron software and found it works extremly well. I can download, run, break point, examine/modify memory, etc, using no additional support software on the target.
I am interested in going with the Keil software since it is much better than what was supplied with Accutron, but I want to use the SPEAR with uVision2.
This is supposed to be possible to do, but I have not found instructions on how to set it up from either vendor.
Does anyone know how to configure the Kiel IDE to use the Spear tool?
