When I compile Make a mistake Seek to answer THX!
Because when compiling. The following information appears...
MAIN.C(1351): error C249: 'DATA': SEGMENT TOO LARGE
Change the small:variables in DATA into the Large:variables in XDATA.
While compiling again. The following information will appear....
Could you tell me what kind of situation it is.
How to solve?? Help to answer it. THX!
*** ERROR L102: EXTERNAL ATTRIBUTE MISMATCH
SYMBOL: DDS_DATA_TEMP
MODULE: tranCode.obj (TRANCODE)
SYMBOL: DDS_DATA
MODULE: DDS_value.obj (DDS_value)
SYMBOL: LATCH_COUNTERvalue
MODULE: Counter.obj (COUNTER)
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?ONUSBSUSPEND?MAIN
SEGMENT: ?PR?MAIN1?MAIN
SEGMENT: ?PR?_TRANSMITDATAEPX?UPSD_USB
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
SYMBOL: TIMEINT2
MODULE: initial.obj (INITIAL)
SYMBOL: SAVEANDRECALL
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
BL51 BANKED LINKER/LOCATER V5.12 09/07/2005 11:41:29 PAGE 161
SYMBOL: TIMEINT2
ADDRESS: 848AH
*** ERROR L118: REFERENCE MADE TO ERRONEOUS EXTERNAL
ADDRESS: B612H
SYMBOL: CUSCL_value
MODULE: upsd_usb.obj (UPSD_USB)
SYMBOL: CUSCL_value
ADDRESS: B8E3H
Program Size: data=174.0 xdata=613 code=47389
LINK/LOCATE RUN COMPLETE. 11 WARNING(S), 131 ERROR(S)
  • EXTERNAL ATTRIBUTE MISMATCH
    Something has been declared with an explicit memory type that doesn't match its real memory space. Given your description, this is probably one of the items you moved from data to xdata. Some other piece of code still refers to it in the data space.
    You have some routines that are not being called. This situation contributes to your running out of data memory. Every uncalled function serves as the root of a new call tree, and the data memory that call tree needs cannot be overlaid with the main tree. Study the manual sections that talk about the overlay analysis.
    Symbol declared, but not actually present in any of the .c files being linked. You don't have a complete program in your project files, or at least your definitions and declarations don't always correspond.
  • Note that you can look-up the error messages in the Manual:
    http://www.keil.com/support/man/docs/bl51/bl51_errors.htm
    You can also click on a messafe, then press F1 to get its description.
    Don't worry about the fact that you have so many error messages; just look at the 1st three - they tell you that your variables DDS_DATA_TEMP, DDS_DATA, and LATCH_COUNTERvalue all have problems.
    Therefore, any references to any of these variables anywhere else in your code are also likely to have problems - and each one may generate more messages.
    Once you've fixed those 1st three errors (as Drew explained), all the rest will probably also disappear!
  • Once you've fixed those 1st three errors (as Drew explained), all the rest will probably also disappear!
    With todays compile speeds (anyone know of more than 5 seconds to compile and link) I would - for general purposes - go as far as "Once you've fixed the 1st error some, if not all, of the rest will probably also disappear"
    If there is no clear picture of whether an error is/could be the result of a previous, do one at a time.
    Of course, my timing estimate above does not include uVision overhead, it is based on commandline (.bat) operation.
  • anyone know of more than 5 seconds to compile and link
    Not that it changes the point, but since you asked: one of my projects takes about 17 seconds to compile all files and about 60 seconds to link. (119 files, a bit under 70K lines of source, roughly 90K of image and 32K of data.)
    The linker in particular seems noticeably non-linear in its run time with respect to project size. When the project was just a wee nubbin of its current self (say around 8-10 KLOC), compile and link was indeed very quick. And of course when it decides to do its global register re-optimization, it takes four passes and more than four times as long.
  • OK, I missed that one. Superoptimization may, indeed extend the processing time dramatically. Believing in the NASA philiosophy "we fly what we test" I do not optimize beyond two. You may ask "what does that have to do with testing?". Simply, if a bug is found at optimization 47 there is no way to debug it since the source and object will have very little resemblance and if I can not debug, what is the purpose of writing code. Also, so called "testing" is, in my opinion, worthless as to finding functional problems, it only serves as a means of finding clerical problems.
    You may have a differnt opinion, I shall not argue beyond what I stated above.
  • "I would - for general purposes - go as far as 'Once you've fixed the 1st error some, if not all, of the rest will probably also disappear'"
    Yes, that would be a very good generalisation.
    "If there is no clear picture of whether an error is/could be the result of a previous, do one at a time."
    Yes.
    In this particular case, it is obvious to me that there are 3 distinct "root" errors - so I would fix the 3 and then rebuild.
    As your method suggests, even with the above observation, I wouldn't bother trawling through all the other messages to try and spot any more unrelated ones - just fix the 3, then address any that are left.
    But, in general, "fix the first one first" stands.
  • "Of course, my timing estimate above does not include uVision overhead"
    FYI: Provided uVision is already open, it adds no more overhead to a build than starting a batch file.
    "Superoptimization may, indeed extend the processing time dramatically."
    It most certainly does - no question at all!
    Particularly the "Linker Code Packing"
    "Simply, if a bug is found at optimization 47 there is no way to debug it since the source and object will have very little resemblance"
    It is possible - just very much more difficult.
    The LX51 Linker produces a disassembly listing of what it's actually done to aid in debugging.
    This is a very big issue that people should really think about very seriously before just jumping blindly into the higher optimisation levels...
    It's the same old story: there's no such thing as a free lunch; you can't have your cake and eat it; the tools can't magically double the 8051's address space out of thin air - the price you pay is loss of debuggability!
  • Where Could you tell me how I should check the question?
    Need to check whether the Address is covered again?
    Need to reduce the use of the variables?
    My variables is under the situation that can't be reduced .
    I deserve and do?
  • "Where Could you tell me how I should check the question?
    I deserve and do?"
    Fix the errors and warnings one at a time starting from the first, as others have told you.
  • Jia,
    Drew explained the cause of your problem:
    "Something has been declared with an explicit memory type that doesn't match its real memory space. Given your description, this is probably one of the items you moved from data to xdata. Some other piece of code still refers to it in the data space."
    So you need to ensure that all your uses of the memory-type specifiers (data, xdata, etc) are consistent.
    Another possible cause could be that you didn't rebuild everything when you changed the memory model.
    You need to rebuild everything!
  • *** WARNING L15: MULTIPLE CALL TO SEGMENT
    SEGMENT: ?PR?_FLASH_BOOT_WRITE_WITH_POLL?FLASHCODE1
    CALLER1: ?C_C51STARTUP
    CALLER2: ?PR?USBISR?MAIN
    Program Size: data=198.0 xdata=608 code=48535
    LINK/LOCATE RUN COMPLETE. 1 WARNING(S), 0 ERROR(S)
    I can not find the question!!!How should I do?
