My master transmitter code is working fine, but i can't get my master receiver running. how exactly is the procedure to receive some bytes from a slave? i tried the following set buffer depth to 1 set data direction to out write slave address with read mask to iic_rtbl generate start condition in the interrupt i received only the address byte, though there were more bytes on oscilloscope. i also tried to set data direction to in, before writing address (which didn't work) and i also tried to set buffer depth to 4, before starting transfer. nothing seems to work properly. any help welcome! thanks in advance
