Dear Keil Community, I have built a digital thermomter using AT89C52. I have to display the temp on a LCD. The ADC is 10 bits and after coversion routines, i get the hex equivalent of temperature as 368. Now 368 is to be diplayed as 3.406 on LCD. .406 is got as follows: 6/16 = 0.375 8/256= 0.031 Adding 0.375 + 0.031, we get 0.406 Please guide me as to how to do this conversion in C51. Thanks for all the Help.
Hi, Why not do exactly as you have described the problem? by creating a float variable to store the result. Say something like:-
unsigned short rawTemp; /* 10bit ADC value */ float actualTemp; actualTemp = (rawTemp & 0xf00) >> 8; /* scale the units */ actualTemp += ((rawTemp & 0xf0) >> 4)/16 /* scale the 1/16's */ actualTemp += (rawTemp & 0x0f)/256; /* scale the 1/256's */
unsigned short rawTemp; /* 10bit ADC value */ float actualTemp; actualTemp = (rawTemp & 0xf00) >> 8; /* scale the units */ actualTemp += ((rawTemp & 0xf0) >> 4)/16 /* scale the 1/16's */ actualTemp += (rawTemp & 0x0f)/256; /* scale the 1/256's */ Or simply:
unsigned short rawTemp; /* 10bit ADC value */ float actualTemp; actualTemp = rawTemp / 256.0;
You've been shown the straight-forward floating-point method. Let me show you the somewhat crude fixed-point alternative:
fraction = ((unsigned long) (dac_val & 0xff)) * 1000 + 128) / 256
Let me show you the somewhat crude fixed-point alternative: Hans-Bernhard, did you forget the much fasterfixed-point alternative Erik
