Hello. I'm a new bie to keil.. am familar with assembly language programming.. i wanna program my 8051's with assemly.. can i write my assembly program using keil.. if yes.. tell me how? Thanks in advance. Wael
can i write my assembly program using keil.. yes if yes.. tell me how? Please read the manual Erik
Thanks for ur Completest ..Clearest Answer Ever.. I have only one thing to not understand.. What is "Please read the manual" :) if u read my message well, i was saying .. am a new bie... more details will be helpful.. i appreciate every piece of help.. even Please read the manual one Wael
Please read the manual: Read The Fine Manual "if u read my message well, i was saying .. am a new bie..." It's hard when you speak in SMS, but it would seem that you are completely new to this, in which case you need to read the manual then ask questions about anything you still do not understand.
have only one thing to not understand.. What is "Please read the manual" Read The Fine Manual I have only one thing to not understand.. What is ur and u ? microresistor and micro does not fit in the text. Erik
Thanks by the way.. u = you urs = yours ur = your etc. thanks again
"u = you urs = yours ur = your" Well, write 'you', 'yours' and 'your' then. SMS is for stupid children. I presume you are an adult?
u = you urs = yours ur = your OK, but why do you mix a foreign language in with the English? Erik
Stop the fight...make peace, let Jesus bring love to you ! ;-) cheers,
nobody is fighting, just hate the Stupid Monkey $#|+ It is rude and discourteous to save oneself a second or two and thus make the tens of people that read the post spend an extra time trying to figure out the Stupid Monkey $#|+. If this was a forum operated on cellphones, then maybe, but it is NOT, everybody has a regular keyboard. Erik
sorry if i distributed you.. but i used to write for my friends like that, so i did not notice when i write it here. it was out of control, sorry again
In Short write them in asm and give them an .A51 extension.
Hi I have access to the Keil software. I would like to use it but everybody (who knows)do not have time to teach me. Is there a simple tutorial that: 1) Gives an example in C 2) Shows how to convert the code (suitable for use in a C51 micro)using Keil. 3) Use Keil to emulate the convereted code Thanks in advance.
Well, to me it makes sense that the way to get started would be to have a look at the "getting started guide" that you find right here. Erik
"Is there a simple tutorial" Yes! The document you require is the uVision Getting Started Guide. Read it, and work through the example projects in it. This will give you a fine introduction to the tools, how they work, and how to use them. (The uVision Getting Started Guide is available on the 'Books' tab in the 'Project' Window; The 'Books' window is also available via the 'Help' menu; failing all that, search for GS51.PDF in your Keil folder) If you have the CD, there also used to be some introductory videos on it that walked you through the tools - dunno if they still do that? Also, take a look at the Quick Start Guide: http://www.keil.com/uvision2/ And there are plenty of examples, application notes, etc in the Support section of this very site!
