I'm trying to build my assembly program to the DS80C400 at Keil uVision2...everthing was ok until I try to change the program start from ORG 000000H to ORG 010000H...now, when I try to build the hex file I receive this error:
Build target 'Target 1' assembling NACSYSsource.a51... linking... *** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: CODE SEGMENT: ?CO?NACSYSSOURCE?0 LENGTH: 0105A2H *** ERROR L120: CONTENT BELONGS TO ERRONEOUS SEGMENT SEGMENT: ?CO?NACSYSSOURCE?0 Program Size: data=8.0 xdata=0 const=0 code=66978 Target not created
LENGTH: 0105A2H something screwy, have a look at the .lst of the module
? I can't assemble it so I just have the .lst from when I used the ORG 000000H. why can't I start my program at 01 00 00H?
The problem may well be that you tried to use class "CODE" for this --- continguous mode code segments should be in class "ECODE".
How and where can I select this? Thanks,
I can't assemble it so I just have the .lst from when I used the ORG 000000H. why can't I start my program at 01 00 00H? It looks like there is no problem with assembling. Which memory areas did you specify for the linker?
In the SEGMENT statement in your .a51 file, of course.
I don't have and don't know how to use such thing. I only use the ORG directive, and I can't find how to use this segment directive. Thanks
I don't have and don't know how to use such thing Then go back to basics and learn how to program assembly. How can you ask about a problem in a module, if you do not know how to make one? Erik
sometimes, when we never had any lessons about that we start making programs without using all that things, until now I never had this kind of problems, just I tried to use expanded adress system. Thanks anyway, Nuno
