I met problem when using DK51 (version 7.01)with ADuc831 microconverter. My developers kit behave like an evaluation version. I have installed an evaluation version before, and removed it when installing the formal version. I have tried: 1. old version. 2. remove all the projects (including .obj files and all other files). 3. reinstall the software (with S/N). 4. Make sure the LX51 option is not checked. However, the code size is still limited to 2k bytes for linking. Anyone has met the same problem before? Any suggestions are greatly appreciated.
You need to rebuild all OBJ files with the full version as explained under: http://www.keil.com/support/docs/1209.htm
