Help to do "sleep" mode
Hi..how can i do a "sleep" mode for 8051?
  • Read & follow the description of "Sleep" mode in the Data Sheet for the particular device you intend using.
    Look for Application Notes & other support material on the vendor's website.
    Check out Keil's support downloads.
    Note that different 8051-derivatives may have different "low-power" modes.
  • Ya..I tried using PCON in my source code, but then i dont know how to check whether there's any effect on my program..i've connected the 8051 with LEDs and there is no difference if i add in PCON or not..how??
  • O.K.
    Most examples of sleep code have you do something like set the pcon bit and then
    just hang. An interrupt will awaken you and you process it, then go back to sleep and
    just hang.
    This was totally unsuitable for my project, as I needed to simply put the machine
    to sleep after some number of minutes of inactivity. I do not have to put it to sleep
    to save batteries. Here is how I did it.
    This is for a Silabs 320
    Several specific things here.
    1. Silabs 320 is running at 24 mhz, and to drop current consumption, I wanted
    to slow the processor down
    This assumes that the wakeup signals (in this case a pair of pushbuttons) are
    connected to int0 and int 1, and I wanted no other way to wake up.
    // now disable all interrupts except for int0 and int1
    saved_ie=IE; // grab a copy of the interrupt enable register
    EA=0; // globally kill all of them
    saved_eie1=EIE1; //
    saved_eie2=EIE2;
    EIE1=0;
    EIE2=0;
    IE=0x85; // reenable global interrupts, and enable int0 and int1
    CR=0; // disable the PCA
    TMR3CN=TMR3CN & 0xFB; // disable timer 3
    // slow the part down to slowest possible clockspeed in this mode
    CLKSEL = 0x00; // Oscillator Clock Select Register ls bits 00 =
    CLKMUL=0;
    OSCICN=0x80; // sets system to internal oscliator /8
    // ensure that all the i/o pins are off
    P1MDIN=0x00; // running value 0xFF
    // shut down other ports the same way
    PCON=PCON | 0x01; // suspend the processor
    // we come out of sleep here
    CR=1; // enable the PCA again
    EA=0;
    // we are going to put code here to switch this to 24 mhz mode
    OSCICN = 0x83; // system clock /1
    CLKMUL = 0x80; // this sets the clock multiplyer to enabled mode
    delay=100;
    while (delay--); // wait at least 5 microseconds
    CLKMUL |= 0xC0; // initialize multiplier
    while ((CLKMUL & 0x20) != 0x20); // wait for multiplyer to be ready
    CLKSEL = 0x02; // system clock is 48mhz/2 i.e. 12 mhz * 4 /2
  • O.K.
    just hang.
    saved_eie1=EIE1; //
    saved_eie2=EIE2;
    EIE1=0;
    EIE2=0;
    CLKMUL=0;
    EA=0;
    delay=100;
  • If the device is a SiLabs 80c51F3xx then it is better to just select the internal osc to the lowest posssible value. Don't go into the idle mode. I don't know the reason but these devices will have a HIGHER idle current in the sleep mode than running at a low osc value. Hope to spend more time on this myself later.
    Bradford
  • "I don't know the reason but these devices will have a HIGHER idle current in the sleep mode than running at a low osc value."
    Not being familiar with this device I don't know for sure, but I would guess that this is because the peripheral clocks are still running when in idle mode. Therefore, if you enter idle with a fast oscillator you may well see higher power consumption than just reducing the clock speed. If you reduce the clock and then enter idle you should get the lowest power consumption.
