I want to write the interrupt routines in assembly ,i don't want to use inline assembly.
cseg at interrupt_vector ljmp isr . . . isr: isr_code reti
A couple more tips: Keep your interrupt vectors and servicing routines in a separate source file (e.g. "IRQ.A51") to save yourself some work. Also, in Jon's code he did not explicitly show you that the service routines are typically placed in a relocatable segment, not an absolute segment. (And if your interrupt service routine is less than 8 bytes, you do not need the LJMP!) So, showing the segment declarations...
IRQ_procs segment code cseg at vector_address1 ljmp irq_name1 . cseg at vector_address2. ljmp irq_name2 . rseg IRQ_procs irq_name1: isr_code . . reti irq_name2: . . .
The file C:\Keil\C51\ASM\Template.A51 contains almost everything that you need.
