I use GetChar() and PutChar() functions to read or write to serial port but when write too long streams using PutChar() it stops at "while(txn > 31)" line in PutChar().. I think the interrupt must go on decreasing the txn value, but not. The program stops running. But the timer interrupt is working and blinking some leds. Whats wrong?? Please help me.
static volatile unsigned char idata rxbuf[32]; // Uart recieve buffer static volatile unsigned char rxrp; // Uart receive buffer read pointer static volatile unsigned char rxwp; // Uart receive buffer write pointer static volatile unsigned char rxn; // Number of characters left in receive buffer static volatile unsigned char idata txbuf[32]; // Uart transmit buffer static volatile unsigned char txrp; // Uart transmit buffer read pointer static volatile unsigned char txwp; // Uart transmit buffer write pointer static volatile unsigned char txn; // Number of characters left to send ..... void Serial (void) interrupt 4 using 2 { if (RI) { RI = 0; // Clear receive interrupt bit rxbuf[rxwp] = SBUF; // Store received character in receive buffer rxwp = (rxwp + 1) & 0x1f; // Advance write pointer rxn++; // Increment number of characters in buffer } if (TI) { TI = 0; // Clear transmit interrupt bit txn--; // Decrement number of characters to send if (txn > 0) // More characters in transmit buffer? { SBUF = txbuf[txrp]; // Yes, store next character in uart buffer txrp = (txrp + 1) & 0x1f; // Advance read pointer } } } void PutChar(char c) { while(txn > 31) // Wait while transmit buffer is full ; if (txn == 0) // If all previous characters are sent... { SBUF = c; // ...write character directly to the uart... txn = 1; } else { txbuf[txwp] = c; // ...else write it to the transmit buffer txwp = (txwp + 1) & 0x1f; // Advance write pointer ES = 0; // Disable serial interrupt while... txn++; // ...incrementinfg numnber of characters to send ES = 1; // Enable serial interrupt } } unsigned char GetChar(void) { unsigned char c; while(rxn == 0) // Wait until there is at least one character in the buffer ; c = rxbuf[rxrp]; // Read next character from buffer rxrp = (rxrp + 1) & 0x1f; // Advance buffer read pointer ES = 0; // Disable serial interrupt while... rxn--; // ...decrementing number of characters in buffer ES = 1; // Enable serial interrupt return c; }
