Translate Error:#112
Do anyone have a clue what's is the meaning of 'Translate Error:#112'.
That come out while I try to define #pragma SRC
  • Have you looked at the lists of error messages in the Compiler and Assembler Manuals?
    In uVision, click on the message, then press F1 - what does it tell you?
    Is there any other information in the message? Please post the full text.
  • Oh...
    The thing is I'm not using uVision as the development software.
    I only use C51 complier to compiler my C code, but anyway here is my compiler output message:
    C51 COMPILATION COMPLETE. 0 WARNING(S), 0 ERROR(S)
    Translate completely and find errors!
    and I can't the meaning of this error number from the C51 manual....
    so...
  • "The thing is I'm not using uVision as the development software ... I can't the meaning of this error number from the C51 manual"
    Are you sure that it's a C51 error?
    It doesn't look like it to me...
  • I said, "Are you sure that it's a C51 error? It doesn't look like it to me..."
    In fact, looking again, I'm sure it isn't!
    If the message really does say:
    You can clearly see that C51 has reported 0 WARNING(S), 0 ERROR(S) - so it isn't C51.
    It must be coming from somewhere else in your build system.
    As you're not using the Keil build system (uVision), I'm afraid you're out of the scope of this forum now...
