Hi there, I hav ethis function call in BASCOM. Printbin Comm_buffer(1) ; 1 Any clues how to write this in C. Thanks Gopal
Not without knowing what it's supposed to do! Please describe the required operation of the function - in fact, doing this may even give you the clue you need to do it yourself!
At a guess, "Printbin" shoves binary data out the serial port. In which case, you could just putchar() inside of a loop to start with. You may want to write a buffered serial port driver (or take a look at the one on 8052.com).
I think Keil's putchar may well do CR-to-CRLF translation? Check the Manual and/or see the source file.
Ok, thanks for the feedback. I was lost because I was trying to send a float by C. It seems printbin is a really smart function that it can send char or float by distinguishing between between them by itself. However, in C, I ended up with writing another function to send a float as 4 separate chars and send them by putchar. Seems no other choice. Also, another interesting point is printbin seems to read the LSB first.
"It seems printbin is a really smart function that it can send char or float by distinguishing between between them by itself" Well, that's just the way BASIC works anyway, isn't it? BASIC basically (!) has no concept of "typing" "another interesting point is printbin seems to read the LSB first" Byte ordering is always implementation-dependent!
"It seems printbin is a really smart function" printf is pretty smart, too!
