there is anybody has used EPM-900 to emulate input capture for LPC932? I'm having troubles with the first capture. ICRAH always come zero at this moment. I'm using input capture for measure a signal and the data captured is stored in xdata memory.
I think that you must check the philips errata note for your IC. It is possible that the input capture doesn't work properly.
I discovered that input capture of LPC932 has a trouble and the CCRH must be read twice to work. Thanks
