I'm looking for the documentation of the MCB900 version 4 board. It seems to be significantly different from the earlier version that is shown on the Keil website. I don't get it to communicate with FlashMagic V1.90. It's using a G-step 89LPC932. Thank you, Franz
Which Baudrate do you use ? and which OS (Win98/ME, Win2000) ? My Board will only work with 9600 Baud. I think, the FM works not correct. Every version from FM have other problems, bugs and features :-( Mike
Thanks for your answer, Mike. I've been trying get the board running on Win2k, without success even at low baudrates (down to 2400). Today I tried it again using WinNT4, where communication worked at 9600Bd and lower. I didn't check out yet to program the chip, because my project software is installed on the Win2k partition. It would be useful to have the schematics of the actual V4 board, anyway. I wonder why Keil doesn't provide the correct documentation with the MCB900. Franz
Schematics of the MCB900 Version 4 are currently available at: http://www.keil.com/support/docs/2725.htm
some 'funny stuff' has been reported in various fora (Philips and esacademy if I remember right) about the 932 running at higher speeds that 7.whatever MHz (the internal clock frequency). Erik
