hi in small project not problem when i chose linker code packing in 92% packed hang and uv2 crash it have bug ?
Are you using the 'Linker Code Listing' option? If so, Try turning that off.
NO
Please check if the problem is still present in V7.09 (Download from http://www.keil.com/update/sw/c51/7.09). If the problem still exists, please send us a test project to: support.intl@keil.com.
