Simulator fails when trying to enter a debug command
Trying to enter for example sendCANmessage (0) into the command line of the Simulator (µV2, Target C515C) the µV2-IDE says "Good-Bye" to me. The same happens at every not-default (user-defined) command when "Space" or a bracket is entered. Even the latest update shows this behaviour! Has anybody else out there seen this problem before and knows how to fix it?
  • There's altogether not enough context in that question to make it answerable...
    The first suspicion would fall into the direction of your user-defined functions themselves. How sure are you that their definitions are correct? Did you try without any definitions of such loaded at all? With only a single, trivial do-nothing function?
